Installing and using Tektronix TDS 210 in LabVIEW 6.1
I am trying to interface my Tektronix TDS 210 Two-Channel scope with labView VIs. I am using the native serial interface on my motherboard without ay sort of PXI card, standard RS232. While Ni had a drivers package for my scope, and I followed the installation docs, my scope still does not work with the LabView environment. The install affected the LabView libs as I can see the options for my scope in the "Instrument Drivers" tap under functions. But when I try and run VIs in that section, I receive this: "Error -1073807195 occurred at tktds2x0 Initialize With Options.vi. Possible Reasons: Driver Status: (Hex 0xBFFF00A5) The interface type is valid but the specified interface number is not configured. Primary
Error: (Hex 0xBFFF000E) The given session or object reference is invalid." Could someone tell me what the soltuion to this is? Thanks.
(3,994 Views)
You do not mention your OS or LV version.
Different versions warrent different suggestions.
Ben
(3,994 Views)
Sorry,
You did say 6.1!
Does the serail port show up in MAX?
Can you open the simple serial examples that ship with LV?
Ben
(3,994 Views)
Well as far as OS and platform are concerned, I am running Windows 98SE. I can see the serial interface in MAX (Meas. and Auto Explorer) as an IVI instrument. It is listed under its correct name of tltds2x0 using ASRL2::INSTR as the resource descriptor. Also the option "simulate" is set to true (1), and I am not sure if that is even relevent.
(3,994 Views)
