I am trying to interface my Tektronix TDS 210 Two-Channel scope with labView VIs. I am using the native serial interface on my motherboard without ay sort of PXI card, standard RS232. While Ni had a drivers package for my scope, and I followed the installation docs, my scope still does not work with the LabView environment. The install affected the LabView libs as I can see the options for my scope in the "Instrument Drivers" tap under functions. But when I try and run VIs in that section, I receive this: "Error -1073807195 occurred at tktds2x0 Initialize With Options.vi. Possible Reasons: Driver Status: (Hex 0xBFFF00A5) The interface type is valid but the specified interface number is not configured. Primary
Error: (Hex 0xBFFF000E) The given session or object reference is invalid." Could someone tell me what the soltuion to this is? Thanks.
