Instrument Not Found
The LabVIEW driver is for use when you're writing the LabVIEW code. It has no bearing on MAX.
What VI are you trying to run, and what error are you getting?
Message 11 of 22
(3,365 Views)
Attached the file 'yk7651.zip' This is the driver from Yokogawa.
I use my own VI's They are in 'My Y 7651.zip' Start with the 'Open Device' VI
Just ask if you have a problem.
Message Edited by K C on 03-25-2010 09:38 AM
Message 12 of 22
(3,356 Views)
What do you want me to ask? I don't have one of those instruments, so I can't run your code. Nor do I have the manual for the instrument. You also have not indicated what error you are receiving.
Message 13 of 22
(3,337 Views)
This was ment for Elahetal.
Message 14 of 22
(3,334 Views)
Thanks KC, I will check your code and keep you posted.
Message 15 of 22
(3,332 Views)
Dear KC, I have Labview version 8.6. How I can use your files? It seems they are version 9
Message 16 of 22
(3,322 Views)
Here you are.....
Message 17 of 22
(3,319 Views)
Thanks a lot KC it worked for me, and I do not know how to appreciate your help  Smiley Happy
Message 18 of 22
(3,298 Views)
Glad to be of help.
Message 19 of 22
(3,281 Views)
hi,
I am trying to communicate to my scope via GPIB.
When I run NI MAX is says no instrument found.
I ran NI Spy and saved the file . Please find the attached file and help me understand what could be wrong?
Ridhi
Message 20 of 22
(2,293 Views)
