Interface specification for GPIB-ENET
I have several GPIB-ENET Ethernet<->IEEE 488 controllers (P/N 181950L-01). For an embedded application, I need to write a driver for this device (preferably in Perl or Python). Where can I find the documentation of the protocol that the GPIB speaks over its Ethernet interface?
Alternatively, if such protocol documentation is not available, source code for Unix/Linux tools and libraries for the GPIB-ENET might also serve my needs.
I can't use any of the binary-only drivers or utilities supplied by NI, because my application does not run on a standard operating system. I need to write a very simple version of a GPIB-ENET driver myself, which I hope should not be too difficult, given the right documentation.
Any help would be greatly appreciated,
Markus
(3,975 Views)
Hi Markus
There are C source code libraries available for purchase, which should allow you to create a driver for the GPIB-ENET device. This package is called ESP-488. Please see the following links:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/430d8f6dae0f500f862568380057cbaa?OpenDocument
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/f519b04553e2b464862569ef00034db0?OpenDocument
Hope this helps!
(3,949 Views)
