serial comunication
Hello my name is Angel, and my email is angelcabezuelo@hotmail.com
I am using Labview 7.1 to do my final project. I need to comunicate my portable PC to a board that I have built with a microprocesor. Anyway I can´t do the test to see if me serial port is running propertly. I have use the basic serial write and read.vi and I have short the pins 2 and 3 of the serial port, but once and again the program say me:
Error - 1073807202 Ocurred at property node in visa configure serial port (Instr).vi - Basic serial write and read.vi
So, do I need to install something in the program to use the serial port? or something like this, because I don´t know what´s happening. How can I use this little program.
Looking forward your answer.
Thank you, Angel Cabezuelo
(3,578 Views)
Install VISA from the Device Driver Reference CD.
(3,567 Views)
Hola Angel,
Dennis is right, it seems the issue has to do with a wrong software installation.
You can check from MAX the software installed (under My System->Software).
You can even open a I/O session with the serial port from MAX (i.e. Devices and Interfaces->COM1->Open VISA session->Basic I/O tab->Write and Read tabs), to verify what may be wrong.
Also, although it may be too much for what it seems a simple issue, you could use NI Spy and capture VISA calls to see what's going on. (It's installed with NI Software at Inicio->Programas->National Instruments->NI Spy).
Finally, though I've never seens this as an issue, verify you have logged in with administrator rights or enough rights to deal with the serial ports.
Hope this helps,
JorgeM.
(3,549 Views)
