Interfacing Zaber Devices with the Compact RiO
I have a cRiO-9025 controller that I'm trying to connect up to our Zaber Devices through a Serial Port Connection.
Because I want to get acquainted with the RiO, I want to upload a simple vi in which I home two motors and then make them move some absolute distance.
My question is this: Do I need to install the Zaber drivers onto the Compact RiO and if so how? And then, how would I move this vi into the device such that I can trigger it from the computer?
Thanks.
(4,770 Views)
Hi
If the Zaber devices have windows drivers, then just forget to use those drivers.
Compact RIO is not running a windows OS.
If these are LabVIEW drivers it can work ok.
greetings from the Netherlands
(4,765 Views)
Got it. Thanks!
One other question. If I want to make something to trigger this program from let's say a Laptop that doesn't have labview, how would I go about building this program?
(4,764 Views)
use an ethernet connection to send a message or via serial or simply via a pushbutton interface.
You can program anything in the controller, but maybe a pushbutton is easiest.
(4,724 Views)
The Zaber instrument drivers are LabView drivers - just standard VI's in a project. Anything that runs LabView and has a serial port should be able to run our drivers.
yours,
Don Kirkby
Zaber Technologies
(4,704 Views)
niced to know.
(4,677 Views)
