09-24-2012 09:09 AM
Has anyone designed any Labview code to interface with the Tripp-lite SU40 UPS device via the RS-485 interface?
Thanks.
09-25-2012 01:58 PM
Hi QRP,
Unfortunately, National Instruments does not supply examples specifically for the Trip-lite SU40 UPS device. You may want to contact Trip-lite and check if they have any LabVIEW examples they can supply. Additionally, depending on the driver you are using, you may be able to find examples for serial IO. For instance, if you are using the NI VISA driver, there are shipping examples for serial write and read. These can be found by going to Help > Find Examples.
Hope this helps!
Dayna P.
Applications Engineer
10-04-2012 11:48 AM
Hello, This is Paul Wampach with the manufacturer. You can get technical support help by emailing 3phasesupport@tripplite.com
Please do not hesitate to contact me directly if you have additional questions or projects.
Paul Wampach |
1111 W. 35th Street | Chicago IL 60609 USA |
