Interfacing with a Tripp-lite SU40 UPS using RS-485
Has anyone designed any Labview code to interface with the Tripp-lite SU40 UPS device via the RS-485 interface?
Thanks.
(3,819 Views)
Hi QRP,
Unfortunately, National Instruments does not supply examples specifically for the Trip-lite SU40 UPS device.  You may want to contact Trip-lite and check if they have any LabVIEW examples they can supply.  Additionally, depending on the driver you are using, you may be able to find examples for serial IO.  For instance, if you are using the NI VISA driver, there are shipping examples for serial write and read.  These can be found by going to Help > Find Examples.
Hope this helps!
Dayna P.
(3,799 Views)
Hello,  This is Paul Wampach with the manufacturer.  You can get technical support help by emailing 3phasesupport@tripplite.com
Please do not hesitate to contact me directly if you have additional questions or projects.
Paul Wampach
  3   Phase Product Manager
1111   W. 35th Street | Chicago IL 60609 USA
  773.869.1279   | Fax 773.869.1020
(3,767 Views)
