Is it possible to control Network Analyzer via Ethernet?
Hi, I need to control my network analyzer.
I did it by using GPIB and by connecting directly the network to my PC.
Now, instead, I have NOT GPIB, but I have seen that my network analyzer has two ethernet ports.
My question is:
1) Is it possible to control the network analyzer by using ethernet?
If YES:
2) Can I connect my network analyzer to my local network and control it by PC in the same network?
3) The only problem can be the distance between my network analyzer and network port on the wall (probably it is needed a very long cable and I have to built it). In this case can I connect my network analyzer to my PC by using an ethernet cable?
4) I know that there are two different cables: straight ethernet cable and cross ethernet cable. What of these two I have to use?
If the direct ethernet connection is possible:
5) How can I test the connection?
6) How can I see my network analyzer in LabView?
Thank you so much,
Luana.
< The Quiter You Become, The More You Are Able To Hear >
Message 1 of 16
(6,966 Views)
You really should be asking those questions to the manufacturer.  We have no idea what instrument you have.  If you can talk to the instrument in any way, I'm sure you can get LabVIEW to work with it.
Message 2 of 16
(6,948 Views)
The Network Analyzer is Rohde Schwarz ZVB. It is possible to find all informations. In particular I have the first in this page:
http://www.rohde-schwarz.com/en/product/zva-products_63492-9660.html
I have the manual, you can find it at this link:
http://www.rohde-schwarz.it/it/prodotti/test_and_measurement/network_analysis/ZVA-|-Manuali-|-22-|-741.html
but I didn't find useful informations (probably also because I have not experience in that field).
Since I suppose that it is possible to connect it via ethernet I have asked the question. I believe that if there is people who did the same can help me better than manufacturer. This is, also, the aim of the forum in general.
Thanks.
Message 3 of 16
(6,943 Views)
Your first link is to the ZVA network analyzers.
Your second link doesn't work.
Message 4 of 16
(6,935 Views)
please have a look in chapter 6 of the manual: http://cdn.rohde-schwarz.com/dl_downloads/dl_common_library/dl_manuals/gb_1/ZVA_ZVB_ZVT_Operating.pd...
This should explain the usage of SCPI and remote control of the VNA in general.
How to get started with Labivew and Rohde & Schwarz instruments is outlined here: http://www.rohde-schwarz.com/en/driver/controlling-with-labview/controlling-rs-instruments-with-labv...
Futhermore the LabVIEW drivers and some getting started info is available here: http://www.rohde-schwarz.com/en/driver/zva/?
Hope this helps for now?
br j.
Message 5 of 16
(6,934 Views)
Thanks nyc.
The second link is divided in two parts, but if you copy it and paste... it works. Try by clicking HERE.
Message 6 of 16
(6,925 Views)
Thanks juergenstraub.
I read the chapter 6 before my post. In my post there are 6 specific questions that I have not solved by reading the chapter 6. I have not GPIB. I have the common cable to connect a PC to router (I have the straight one and the cross one). It seems that there is no topic about the possibility to connect directly the Network Analyzer directly to PC via ethernet. Plese give me an advice if I fall in error,
thanks again,
Luana.
Message 7 of 16
(6,922 Views)
From that Chapter 6 in the manual
Remote Control: Introduction
The instrument is equipped with different interfaces for remote control:
• A GPIB bus interface according to standard IEC 625.1/IEEE 488.1. The GPIB bus connector for
control of the analyzer from a controller is located on the rear panel of the instrument.
• Analyzers connected to a Local Area Network can be controlled via the RSIB or VXI-11 protocols.
Two connectors for LAN connection are located on the rear panel. A VISA installation on the
controller is required.
• The network analyzer can itself act as a master and control external devices (e.g. power meters,
generators) via LAN, USB, or GPIB interface. A VISA installation on the analyzer is required for
this remote control type.
Message 8 of 16
(6,915 Views)
Message 9 of 16
(6,911 Views)
Thanks nyc and juergenstraub.
I read that lines 😉 And I read, before you will write,  the Remote Operation in a LAN on the Quick Start Guide (pag. 26 to 31). Remember that for me it is the first time: I have NO experience.
I don't find information about the cable that I have to use:
if I want to connect my PC to Network analyzer is it necessary straight ethernet cable? Or cross cable?
I will try to create a LAN between Network Analyzer and my PC...
As soon I have this information... I will start... and I hope that all will be fine 😉
Luana.
Message 10 of 16
(6,903 Views)
