Is it possible to control Network Analyzer via Ethernet?
Typically, you use a cross-over cable when connecting a pc to a network device and a straight through when you connect to a hub/switch.
Message 11 of 16
(1,688 Views)
Hi All.
I posted my NEW question in the LABVIEW Forum, but, probably, it was the wrong place, sorry.
This is the link of new question:
http://forums.ni.com/t5/LabVIEW/Good-Communication-but-Error-in-Example-Manufacturer-VI/td-p/2259014
Can you give me same advices?
Thanks in advance,
Luana.
< The Quiter You Become, The More You Are Able To Hear >
Message 12 of 16
(1,676 Views)
@SweetLuana wrote:
Hi All.
Thanks in advance,
Luana.
Don't spam the message boards.
Since you started a new post on the LabVIEW board stay with that post!
Message 13 of 16
(1,672 Views)
Sure nyc.
After my post I thought that, probably, was the bad place, but I was NOT able to change the forum.
If you can put my question in the "Instrument Control" forum please.
Luana.
Message 14 of 16
(1,664 Views)
@SweetLuana wrote:
Sure @nyc_(is_out_of_here).
Luana.
Your question is being answered very nicely in the LabVIEW forum.
Message 15 of 16
(1,659 Views)
Sweat Luana programming the Network Analyzer in TCP/IP vs GPIB is no different if using the VISA control enviroment. If you click to pull down the instrument control with the Network Analyzer connected with the right TCP/IP connection (see note about hub or cross over connection) then if the TCP/IP address comes up, select it instead of the GPIB address. Nothing else in the VISA driver has to change. Whether you control and code with GPIB or TCP/IP the action will be the same. The power of the VISA connection and drivers. I used this feature many times to connect GPIUB or TCP/IP.
Message 16 of 16
(1,651 Views)
