Is it possible to run two LabView executables on the same PC at the same time?
Is it possible to run two LabView executable programs on the same computer at the same time or does LV not allow multiple instances to run on one PC.  I should also mention that I'm using two USB to serial cables on one PC.
Any advice would be helpful.
Jefska
(3,440 Views)
A simple answer to your simple question would be yes.
What exactly is the problem you are having? You cannot connect to the same serial port with the different executables. You should be able to connect to different ones though.
Message Edited by Dennis Knutson on 05-12-2008 10:05 AM
(3,439 Views)
Just wanted to know before test setup on the PC.
Thank you.
(3,422 Views)
