Is there a LabVIEW driver for MicroMotion Mass Flow Meters?
Hi, I'm looking for LabVIEW Drivers (VI's?) for the Mass Flow Meter CMF 010P by Micro Motion (combined with MVD Electronic 2500) and the Mass Flow Meter 5850S by Brooks Instrument. Can anybody help me?
(5,563 Views)
You can search www.ni.com/idnet for all kinds of instrument drivers. if you can not find a driver for your device here, another chance would be to ask the vendor.
(5,553 Views)
Thanks for your Message, but I already did these things you're proposing. Is there any other possibility to get the driver I want?
(5,545 Views)
If you can not find one on www.ni.com/idnet, and even the vendor does not offer a instrument driver, then there is none available. You can request a driver on www.ni.com/idnet, but it is not sure that a driver for this device is programmed then. This depends on how many people request that driver. Even if one is made it will take a while until the driver would be finished.
So unfortunately I think the only fast solution is to use standard VISA functions to communicate with your device.
(5,540 Views)
Have you a solution to this problem? I also need a "driver" for a MicroMotion 2700. Is this available or have you made an .VI for this?
(5,134 Views)
