Is there a driver to use a PCMCIA-232/4 card with windows 7? or is there one is the works?
(3,256 Views)
If there are Vista drivers, you can try installing them in Compatibility mode.
(3,252 Views)
Hey jsebree,
Unfortunately, we don't have a driver that supports the PCMCIA-232/4 on Windows 7.  The first version that supports Windows 7 is the first version that does not support the PCMCIA card.  Sorry that it turned out this way!  The first Windows 7 compatible version is NI-Serial 3.5.1, which is the same version that the PCMCIA card stopped being supported in.  Feel free to look at NI-Serial readme if you have any other questions!
(3,239 Views)
