Is there a way to use an older downloadable driver that don't load on 6I?
I got an error loading a driver for a Transient Digitizer TRC 4020. Is it possible to convert it to 6I? I got this older Transient Digitizer for education of our students in our institut (for instr. Impact test). It came with an old XT and the software isn't running anymore. I'm using 6i and i've found this driver in the database but it will only run with an older verion of Labview 😞
(3,455 Views)
LabVIEW 6 can load and run code developed in LabVIEW 4.0 and later versions of the environment. The 4020 driver I found has a component developed in an earlier version of LabVIEW that is not compatible. If you can load it in an alternate version of LabVIEW (5.1 etc), you should be able to mass compile the vi's using this alternate environment and then load them from 6.
(3,455 Views)
