how do I use vireadtofile
(4,778 Views)
Are you having a problem using this function or do you just want to know how to use it?
(4,778 Views)
Thanks for your answers. I have tried using this function under Visual Basic 6.0 with Service Pack 5. The function creates a file as expected, except that the file contains the wrong data. Can one use this function for any data type, or only for "arbitrary block data"?
(4,778 Views)
Documentation on the function can be found on page 5-115 of the reference manual (http://www.ni.com/pdf/manuals/370132a.pdf)
Ryan Mosley
National Instruments, Applications Engineer
http://www.ni.com/exchange
(4,778 Views)
Thanks Ryan. I have downloaded the manual file and will read it later. I have seen that VISA 2.5 runtime is available for download on your website. I would like to get the development version. A CD is mentioned there, but no reference as to how to get one. Can you help ?
(4,778 Views)
