Issue with Initializing hp33120a
I have had a time trying to set up the control for an Agilent 33120A connect via TCPIP on a GPIB E5810A. I am new to LabView still, so I was doing this as part of the core 1 module 30 training but will need it when testing software developed with LabView 2012.
I have the following error screen (ErrorWInstrumentDriverFinderVI… attached).
I also stepped through the VI I found in the Instrument IO explorer called hp33120a Example – Generate Std Wfm.vi and see that the error begins in the hp33120a Initialize.vi subVI. (ErrorInInitialize.jpg and Error_probeview.jpg).
I have no clue where to go from here. I had no trouble connecting to another Waveform Generator 33220A via USB. But I borrowed that device and the above (old one without USB) is what I am stuck with using… L
Please give me some idea what could be wrong or where to look to give you more information to help me.
(3,550 Views)
what is the resource name you are using?
greetings from the Netherlands
(3,531 Views)
