Keithley 2400 Problems
use the example
In the menu goto  Help / Find examples
In the example finder goto Hardware input output / instrument drivers / LabVIEW plug and play
try Keithley 24XX Output List and Acquire.vi
greetings from the Netherlands
Message 11 of 33
(4,735 Views)
Thank you for your reply. I tried Keithley 24XX Output List and Acquire.vi , but when I run the file there are errors as: Sub VI is missing. is there any way to solve this?
Message 12 of 33
(4,720 Views)
Is your NI Software up to date? I had the same problem once and I used the NI Update Service to update the Software.
Which SubVIs are missing?
Message 13 of 33
(4,712 Views)
Sub VI missing is solved ba replacing the file.  When I run the keithley 24xx output list and acquire.vi i have an error. you can see in attached file.
Message 14 of 33
(4,701 Views)
The error is that you ask something from the K2400 that is not allowed.
Could it be that the combination of 0.1 Amp compliance and 0.1 Volt is not allowed?
What is the Voltage limit?
It is possibkle that the order in which the limits and source voltage is programmed generate such an error,
What vi did you replace?
In my system the example  loaded without errors
Message 15 of 33
(4,674 Views)
First, the examples did not run because of wrong path directory . Hence I saved Keithley 24xx in instr.lib of labview 2013 . I chose current rang as 1 mA and voltage limit as 1 mV.
Message 16 of 33
(4,651 Views)
I'm a bit confused about using Labview with Keithley 2400.  Does it need to send any command through communicator to keithley240xx ?
Because I thought , I just have to connect the keithley to my laptop and then run the Labview.
Message 17 of 33
(4,644 Views)
You are communicating to the instrument with LabVIEW so I don't understand your question.
One thing to check is if the driver is correctly using your local decimal settings. Try changing to a period and see if that makes a difference.
Message 18 of 33
(4,636 Views)
That are small lomits.
And indeed the driver is expected to be in the instr.lib.
If you installfrom labview it will automatically be installed there.
Message 19 of 33
(4,626 Views)
Hello People,
I am having the problem with the keythley 2400 sourcemeter. While working or measuring my solar devices this instrument is getting turned off and i have to switch it on again to work. Please suggest some solution...having hard time resolving it. 😞
Message 20 of 33
(4,367 Views)
