Hi All,
I am using a Keithley 2701 DAQ and a 7700 20 channel multiplex module. For my experiment, I need to sense small values of current (nanoAmps), so I can detect changes in that current. I'm using LabView and the provided Keithley drivers to read the two current sense channels on the multiplex module. The Keithley has a resolution of 6.5 digits. That's set by default actually. The range is set at AutoRange. I tried sensing the current; however, I had no luck. It seems that the Keithley machine was not able to resolve the nanoAmp signal it was being given. All I got was noise.
I've been assured by the Keithley engineers that the device has a resolution of down to 10nanoAmps; however, the resolution is already set at the highest value in LabView. Is there another feature I've been overlooking in the Keithley drivers?
