Keithley 4200- GPIB - agilent 81110a pulse generator
I'm a master student and majored in PCM(phase change memory).
Now, I have several instrument: Keithley 4200, GPIB, Agilent 81110a pulse generator for PCM measurement.
I need a program that Keithley 4200 controls Agilent pulse generator.
My task is, firstly, measure PCM device current with low DC sweep by Keithley; second, connect PCM device to pulse generator with SMU and apply a voltage pulse with short pulse width to the PCM device; third, connect PCM device to Keithley and measure the current with low DC sweep again.
And repeat the task by increasing the pulse voltage or width.
I need this kind of program code. Could anyone help me??? Is there anyone who have this kind of code or similar code may help me????
Thank you~~~
(4,065 Views)
(4,064 Views)
Are you actually using LabVIEW?
If so, it would be a good idea to actually learn how to use it.  LabVIEW - Six Hours
(4,050 Views)
