Where is the GPIB-USB-HS user's guide?
I have not seen a GPIB-USB-HS user's guide, hard copy or online version. Where do I get additional info about Hardware overview, operation, interfacing notes etc...
For instance the NI  GPIB-232CTA comes with a 200 page user's manual.
(5,149 Views)
Start>Programs>National Instruments>NI-488.2.
You should have found the on-line documents simply by going to the product page and clicking on the 'Resources' tab.
(5,142 Views)
Thanks for the reply Dennis. The problem is that there is information only on installation of the GPIB-USB-HS, what I am looking for is architecture, features and operations. It looks like there is no detailed description for this controller.
I just finished writing an application (for Windows/Linux/Solaris) using the NI serial to GPIB controller, GPIB-232CT-A.
I did that by sending/reading ASCII commands to/from the serial port using system write/read commands.
What I would like to know if the same can be done with NI's GPIB-USB-HS by using a generic I/O USB kernel driver (such as the open source libusb or libUsbWin32 drivers ) I am particularly interested in this because of the the GPL requirement for USB kernel drivers when using Linux kernel > 2.6.25 .
thanks again.
(5,138 Views)
I don't know if that sort of information is available anywhere on any of the controllers. A GPIB controller is quite a bit different than a simple com port. As far as I know, you need to use either the NI-GPIB or VISA library. Perhaps someone with more detailed knowledge will correct me.
(5,133 Views)
In GPIB-232CTA all the GPIB comm. handling was embedded in the controller. Your app only has to send/receive simple ASCII strings through the serial port, in my implementation I did not use any GPIB or VISA drivers.
My question is NI's GPIB-USB controller the same way or all of the GPIB handling was shifted into the NI GPIB driver? Is a 488 GPIB driver necessary or it is optional as in GPIB-232 CTA?
thanks
(5,124 Views)
As I said, I believe you have to go through the 488 driver. Your comparison to the RS232-GPIB converter is not really relevant. The USB does not in any way emulate a serial port.
(5,106 Views)
