Keysight DAQ970A sending SCPI commands
I have not needed to load any drivers other than VISA when communicating with the instrument via SCPI.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 11 of 13
(1,235 Views)
Right...
I was just having difficulty with the most basic SCPI commands like *IDN?\n in NI MAX even when I verified the VISA session to the device.
My solution was to get .NET 3.5 turned on and made sure I had IVI configured correctly as the DAQ970 drivers I pointed to are indeed IVI.
Message 12 of 13
(1,227 Views)
The DAQ970A driver on the NI site has a bug with the measurement setup VIs.
Specifically, the voltage configuration commands are wrong - The DAQ970A doesn't support all the options that the VI sends. See page 106 of the DAQ970 programming guide. The attached VI fixes these issues.
Message 13 of 13
(951 Views)
