LabVIEW Build errors
An error as follows has occurred when building the exe file:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1502 occurred at Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Cannot save a bad VI without its block diagram.
Method Name: Save:Target Instrument
The code was built successfully in all previous version. Only a few minor changes to the latest code: a global variable was added and a few calculation algorithm were updated.
Does anyone have any idea about this error?
Thanks in advance,
Jean
(5,545 Views)
Try selecting Do not disconnect type definitions or remove unreferenced members under Additional Exclusions when you build your executable.
Also try enabling debugging.
(5,529 Views)
Thanks a lot for your help, this issue was solved by enable debugging in the build specifications.
Jean
(5,483 Views)
Thanks I had the same problem. Enabling debugging did also the trick for my application
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(5,098 Views)
I resolved the issue by setting the following build properties
 - disconnect type definitions
 - enable debugging
 - unselect SRS
Thanks for help
(4,602 Views)
