LabVIEW and Proteus comminication settings (RS232) HELP...
Hello friends,
LabVIEW with the PROTEUS programs via rs232 want to light an LED. But I'd done, I can not run a kind of study. I do not know where the error was doing. Would you please help. THANKS.
CSS C CODE:
#include <16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=4000000) // Gecikme fonksiyonu için kullanılacak osilatör frekansı belirtiliyor.
#use rs232 (baud=9600, xmit=pin_C6, rcv=pin_C7, parity=N, stop=1,FORCE_SW)
#use fixed_io(d_outputs=PIN_D0,PIN_D1,PIN_D2,PIN_D3)
void veri ()
char x;
gets(x);
if(x=='A')
output_d(255);
return;
void main()
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
//output_d(0x00);
while(1)
veri();
Proteus DESIGN :
VI Programı:
VI PROGRAM:
FILES : http://cid-7720cfbabd88a5d6.office.live.com/self.aspx/PROGRAM/led%5E_lab.rar
THANKS
(10,472 Views)
I am not too familiar with the Proteus board but here are some links that may help.
http://www.sonsivri.com/forum/index.php?topic=24603.0
http://ayushdewan.wordpress.com/tutorials/serial-servo-using-labview-and-proteus/
I hope that this helps.
Perry S.
(10,451 Views)
I dont understand what you trying to do. Can you still be specific? What actually is the problem that you are facing? Is it just that the LED's are no glowing?
"Winning isn't everything, Its the only thing"
(10,448 Views)
