LabVIEW will not recognize physical channel in DAQ assisstant when MAX shows it Running.
Ni cDAQ-9184 is connected to laptop with ethernet cable. System state says running and a NI 9481 module is in slot 1. However, when I try to add device, I get error 201401. I am trying to get the DAQ assisstant in LabVIEW to recognize the physical channel but it is not doing so. Laptop is not connected to the internet if that's an issue.
(4,361 Views)
Hi there,
Try disabling the wireless network adapter, the antivirus and the firewall. Next, Make sure the hardware is visible in MAX and you can use the test panels on the module.
If that doesn’t work I recommend taking a look at this similar thread.
Alejandro C. | National Instruments
(4,328 Views)
