incremented voltage output using DAQPad-6259
I'm really new to Labview and trying to make a program that increases the output voltage overtime using my DAQPad-6259. Basically I want to start from a certain voltage and then given a specific time interval, the voltage will increase at a certain rate. Ideally I want to go up and down a certain voltage range if it's possible. Like say the voltage will go up and down from -5V to 5V at a certain rate until I tell it to stop.
I tried making a lousy excuse of a program using LabView 8.5, but the output doesn't change.
I'd greatly appreciate whatever help that you guys might be able to extend. Thank you.
Cheers,
rakue
(4,427 Views)
Hi Rakue,
What version of DAQmx are you using? Have you looked into the onboard examples (Help > Find examples) to try and find an analog output example?
Bobby Breyer
(4,395 Views)
