LabView 8.5 and NI-488.2 error: I/O operation aborted (with MI Bridge 6010 and thermometer)
Hi ,
i've got a new issue: using LabView 8.5 and a GPIB-USB-HS connection, NI 488.2 drivers are installed,
I encounter an error such as : NI 488.2 I/O operation aborted (this error drop the running of LabView application found in the example application)
I'm trying to link a 6010 resistance bridge by the Measurements International, which is link to a resistor (known) and an unknown thermometer.
LabView detects MG2000 drivers, but by using the applications built upon it I get different errors such as : Error -1223 occurred at MG2000 Initialize
Can you help me?
Thanks Davide
(4,677 Views)
Hi Davide,
maybe the driver you're using are not completely fitted for your device:
http://digital.ni.com/public.nsf/allkb/862567530005F09C862564BC007F0FD4?OpenDocument
Can this be your problem?
Byebye
(4,665 Views)
One of the problems is the drivers, without any doubt, the second one is that to find the instrument driver for a 1997 reitance bridge is hard, and I don't have the skills and the time to make a new one.
Do you know if I can find that???
(4,662 Views)
Double clicking the VIs of the driver can you enter in the block diagram of that?
Maybe looking on the inside of the VIs of the driver, with some changes they'll be good for your instrument too...don't know that for shure, but if you downloaded a version of driver for an instrument similar to yours, maybe the changes to make are few...
(4,660 Views)
Hi, don't know if you managed to solve the problem, but every driver available from NI can be found here:
http://www.ni.com/idnet
Hipe it helps,
bye!
(4,616 Views)
