MAX can not find "GPIB-USB-B" under" Devices and Interfaces"
I am using Labview 2010 with windows 7 system (64bit).
I am trying to work on some program for Keithley 2700, connected with "GPIB-USB-B" with my computer.
The problem is that MAX can not find "GPIB-USB-B" under" Devices and Interfaces" from time to time, everytime I have to restart my computer to find the device. The driver I used is NI-488.2.2.81.
Is there any advice that I do not need to restart computer agian and agian?>
(3,794 Views)
If your device is not listed, then I strongly recommend you to check the VISA Passports. To check the VISA Passports, open the NI Measurement & Automation (NI Max) utility and click on Software->NI-VISA, go to the VISA-Options tab, click on Passports and ensure the NI-VISA Passport for GPIB is marked off and the KEVICec Visa Passport for GPIB is marked on.
Miguel Fonseca
(3,771 Views)
HI, Thank you for your reply.
But I can nond find KEVICec Visa Passport for GPIB. The setting for passport is attched.
(3,758 Views)
