Labview 9 with GPIB-RS232 for controlling shutter at fixed interval of time
I want to control my shutter using LabView. I have got a program for it from which I can see that shutter is being controlled. But I don't know how should i incorporate this conditional opening and closing of shutter. For example, I would like shutter to be close for  first "t1' sec and open for next "t2" sec and again close for "t1" and this repeated over unless stopped.
I am attaching the file also, Can somebody explain me how I can do it?
Thanks and regards.
(4,585 Views)
Accepted by nns2006
Hi
What you need is two arrays with in the first the on times and in the second the off times.
Then in a for loop switch on, wait element on, switch off wait element off.
Use autoindexing and make sure that both arrays have the same length otherwise the shortest array will determine the last steps.
(4,571 Views)
I'm thinking this would be a good application for a State Machine.
(4,565 Views)
I have managed to find the solution. thank you for help
(4,554 Views)
I completely agree with the statemachine proprosal.
Especially the sequence structure used now is really not necessary (two empty frames and everything is already connected by error wires)
Instead of the old sequence structure please use the new flat structure.
The only extra comment I would make is to connect all error wires instead of starting again in a frame.
(4,539 Views)
