Labview Network Analyzer Calibration
Hi there.  I'm fairly new to labview, and am currently retrieving s-parameters from a PNA analyzer (agilent 8362B).  I'm using the drivers found for this analyzer on the ni website, and am trying to add a calibration feature that allows me to calibrate directly from the labview program rather than the pna analyzer.  Does anyone know which file I should look at or what others steps I should be taking?  So far whatever I use results in an error, such as CALC measurement selection set to none (error 103)
thanks in advance
(3,887 Views)
Duplicate post.
You might want to post the VI or screenshot of what you are modifying to better see what is missing - on the original post.
http://forums.ni.com/ni/board/message?board.id=140&message.id=23917
(3,864 Views)
