FB6000 W/ RS-449 module, using G.P.I.B. interface need to change between DTE & DCE-TT
I'm using a Fireberd 6000 with a RS-449 interface module,  (41400) I'm running a couple different tests which require slightly different settings on the module.  I'm using G.P.I.B. as an interface. I need to find out if there's a way I can change between DTE & DCE-TT. (located in the intf setup->mil449->rs449->con->d-type). If anyone has any idea, let me know. thanks,
Kris
(3,258 Views)
Nevermind, got it. one call to JDSU tech support, got the manual for the 41400 found page 42 and we're done.
Kris
(3,248 Views)
