I'm using a Fireberd 6000 with a RS-449 interface module, (41400) I'm running a couple different tests which require slightly different settings on the module. I'm using G.P.I.B. as an interface. I need to find out if there's a way I can change between DTE & DCE-TT. (located in the intf setup->mil449->rs449->con->d-type). If anyone has any idea, let me know. thanks,
Kris
