Labview communicating Modbus device
Hi All,
I am trying to communicate with modbus device using labview 8.5, which I did communicate using windows hyperterminal.
Can anyone help me in this regard
I would appreciate quick help
thanks
Nadz
Message 1 of 20
(8,209 Views)
Help with what?
By the way don't duplicate posts.
greetings from the Netherlands
Message 2 of 20
(8,202 Views)
Accepted by topic author Cube404
You will need to download and install the ni_Modbus_8.2.exe
and follow the instructions to install this for LabVIEW 8.5
There are examples on how you use the modbus vi's.
Christian A
Message 3 of 20
(8,192 Views)
Hey Christian,
Thanx for that, I will download it and follow the instructions..
cheers
Nadz
Message 4 of 20
(8,150 Views)
Hey Albert,
I am new to Labview and modbus...
I appreciate your reply too.
thanx
Message 5 of 20
(8,148 Views)
Hi Christian,
Thanks for the solution..
Now I can communicate with the device,
one more help please, how can I read particular register value of the device?
Thankx
Nadz
Message 6 of 20
(8,120 Views)
Hello Nadz,
If you take a look at the Master and Slave vi's there are case structures where input registers and coils are being read.
Please go over these and let us know if you have any further questions.
Christian A
Message 7 of 20
(8,080 Views)
I'm using the same modbus drivers with and emerson AC drive, I have an issue when I'm trying to read negative numbers (data) from the registers i'm receiving the data as a U16. does anyone know if these drivers exist for signed integers as well or what the procedure would be to convert the modbus data recieve as signed integers?
PS . I have the NI Modbus library and  my code works just fine when I'm moving in the positive firection the problem arises obviously when I reverse directions I receive a large number and even though it still sounts down.
thanks for any input...
SB
Message 8 of 20
(7,589 Views)
Hey SB,
Even I had the same negative values problem...but it solved by doing some calculations....
please let me know, what are the values ur getting there, when u were expecting 0,-1, -2....
so that I can help u in a right way....thanx
Cube
Message 9 of 20
(7,564 Views)
Mr_TesT,
The modbus library returns an unsigned integer that in your case needs to be converted to a signed integer.  Just use one of the conversion functions located on the Numeric>Conversion palette change to a signed integer.
Message 10 of 20
(7,550 Views)
