using visa serial port to receive nothing (labview 8.0)
i have a problem in my vi. I use visa serial port to read  and write from same port to check the outcome but nothing come out.
can u help me plz.
Message 1 of 16
(5,916 Views)
How did you wire up the serial port? Did you short pins 2 and 3? Did you try using Hyperterminal to test your connection?
Message 2 of 16
(5,905 Views)
yes
pin 2 to 3
 and i try hyperteminal too but cannot recevie
i using labview 8.0 and 8.2
Message 3 of 16
(5,904 Views)
If Hyperterminal does't work either, then there's probably something wrong with the hardware (either the port or your wiring) and the version of LabVIEW is not relevant. Is this a built-in port or a USB->RS232 converter? If you have a different built-in or a different converter, try that. Or, try it on a different computer.
Message 4 of 16
(5,870 Views)
i trying hyperteminal to hyperteminal ok
i send using labview 8.0 and 8.2 to hyperteminal ok
Message 5 of 16
(5,867 Views)
I'm confused. In your previous post you said Hyperterminal was not working. Now it is? What did you change? Your second statement is also confusing. You cannot use Hyperterminal and LabVIEW for the same port so what did you do for this Hyperterminal to LabVIEW test? A serial loopback test with Hyperterminal is described here. A simple LabVIEW test is attached.
Message 6 of 16
(5,844 Views)
i using two computer to test but some time one com.
when using two computer i use hyperteminal to send from this com and  other to recevie by using labview.
Message 7 of 16
(5,836 Views)
These are details that are important to include. So, when you use a single port on the same pc, it doesn't work with either Hyperterminal or LabVIEW but if you use two separate pc's it works. If that is the case, then I would think that the whole problem is with the little serial loopback you have on the single pc. Make sure it is a real short by using an ohmeter and verify that it is really pins 2 and 3 and not pins 3 and 4. If you using something like a paper clip, make sure the connections are tight. I prefer to use a male plug and solder wires on the back.
Message 8 of 16
(5,835 Views)
But i can send by using labview to hyperteminal but not recevie the info send the hyperteminal?
Message 9 of 16
(5,828 Views)
have u try my vi try it pls
Message 10 of 16
(5,823 Views)
