using visa serial port to receive nothing (labview 8.0)
I cannot run your VI upon opening it because of E:\0743_Wujingrui\Enum.ctl and Control1.ctl.
In your VI are you trying to send just the Y, U, or V alone...or combined all together?
Message 11 of 16
(1,848 Views)
After getting rid of the type defs, I was able to run the VI and saw data with my loopback in place. It will run much better if you put the VISA Configure Serial Port and VISA Close outside the loop and if you put a small wait inside the loop.
Message 12 of 16
(1,845 Views)
it is done thank you  Dennis Knutson
Message 13 of 16
(1,824 Views)
hi dennis,
               i'm using usb GPIB HS to communicate with an antenna using hp network analyzer. my MAX detecting gpib but i dnt know how to use labview to read data wt my antenna is getting after reflection from the object.please help me
Message 14 of 16
(1,387 Views)
hi dennis,
Message 15 of 16
(1,384 Views)
duplicate post and off-topic
Message 16 of 16
(1,369 Views)
