Labview revision for GPIB ENET
I am quite new to labview, last week I used one labview program to control a PCB board ( for debugging fpga and no other instruments) through a  computer with GPIB connector , now I have to use another computer ,which has no GPIB connectors. I am going to use a GPIB-ENET adapter to control this board, I don't know if there something I should change in my current labview program because I have to deal with the ethernet now.
Thank you for your help.
Wei
(3,834 Views)
you have to configure your GPIB-ENET.
When you connect your instrument you should find it in Max.
Now you can use the usual examples in LabVIEW for GPIB communication.
To find examples you can use the NI Example finder.
Just start it from the LabVIEW start screen or from the menu:
Help -> Find Examples... -> search for GPIB
Here you can find additional Info to GPIB-ENET:
http://zone.ni.com/devzone/cda/tut/p/id/3264
Plamen
National Instruments Germany
Application Engineer
(3,809 Views)
