Latest Agilent MSO drivers not returning all waveforms
thanks Charles!!
taht worked (there was an error - you connected the first 'F' to a void input rather than one above).
I now see the correct FFT 'pattern' on the screen, but the scales are wrong. The X should be in Hz and the Y in dBV. Any idea how to fix this? (I have no idea about Labview really). I tried changing the Y to log but lost the trace!
Thanks again
Tony
Message 21 of 22
(1,187 Views)
Hi Tony,
I think the amplitude of FFT waveform displayed in LabVIEW is exactly the one in the scope screen. The amplitude unit should be the one you have manually set or a default unit in scope.
If you would like to change the graph control axis name, please double click the name text and edit it directly.
Yours,
Charles
Message 22 of 22
(1,181 Views)
