‎11-01-2006 07:22 AM
‎11-01-2006
07:33 AM
- last edited on
‎05-27-2025
10:18 AM
by
Content Cleaner
The SCB-68 is a dumb terminal block and does not require any software to run. Whatever you have connected to it probably requires some sort of software and you need to provide that information. You posted to the instrument control forum which is normally for GPIB and serial type instruments. Is that what you have connected or is it an NI data acquisition board? For data acquisition hardware, the latest drivers can be found at https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html.
‎11-01-2006
08:14 AM
- last edited on
‎05-27-2025
10:18 AM
by
Content Cleaner
Thank you for the fast reply. I apologize for posting in the wrong thread, it is an NI data acquisition board I am using (I think), definitely not a GPIB.
I went to the link where the latest drivers can be found but I unsure what to install. I clicked on "NI-DAQmx Version 8.3 for Windows 2000/XP" and downloaded "NIDAQ830.zip ".
I ran setup.exe in the NIDAQ830 folder but I am thinking these were the wrong steps. Please offer a little more direction if you can.
Thanks again!
‎11-01-2006 08:53 AM
‎11-01-2006 10:05 AM
Aout = analogoutput(
'nidaq','Dev1');Error I get is:
??? Error using ==> analogoutput.analogoutput
Error using ==> analogoutput.analogoutput>localCreateAnalogOutputObject
The specified device ID is invalid. Use DAQHWINFO(adaptorname) to determine
valid device IDs.
I took your advice and searched further in the correct forum but still could not come up with my answer. Are you able to offer a little more help now?
‎11-01-2006 10:43 AM
‎11-02-2006
02:30 PM
- last edited on
‎05-27-2025
10:19 AM
by
Content Cleaner
Hi Tyler,
Dennis is correct in saying you don't need to worry about the SCB-68. The board in your PC is the PCI-6704, which is an analog output board; so far so good as that is what your MATLAB code appears to be trying to do. I have a question about one of your comments.
"The name is "Dev1". For some reason I was able to select "self-test" and the other buttons on the device but no longer am I able to do that."
Does the device no longer appear in MAX at all, or can you just not select "self-test"?
If the device is not appearing in MAX, we need to check if it is appearing in Device Manager. It should appear in MAX with an NI eagle icon next to it.
I can not say what your MATLAB code is doing, but if the board is not working properly in MAX it will not work in MATLAB.
I think the best way to proceed is to try and make sure your board is outputting signals to your SCB-68 just using the test panels in MAX.
This link should give you a good idea of how to check out your card in MAX.
If everything appears to work fine in MAX, then you can start testing out your MATLAB code and you will not have to worry about the hardware difficulties.
Happy thermocouple Thursday
Michael
Message Edited by Mike_D on 11-02-2006 02:31 PM
‎11-02-2006 02:36 PM
‎11-06-2006 12:24 PM
Mathworks suggested I uninstall and then reinstalled MATLAB. Now everything is working fine. It seems that certain files or directories were not in the correct place.
Thank you to everyone who replied with helpful comments.
