LeCroy WavePro 7000 drivers
Has anyone had any success working with a WavePro 7000 with LabVIEW? I'm using TCP/IP with the WavePro 9xx drivers and I've yet to be able to even get it set for an aquisition.
(4,086 Views)
What instrument driver are you using? I looked in www.ni.com for the LeCroy drivers and I only found the driver for the 7200.
In any case, Can you configure the TCP/IP resource in the Measurement and Automation eXplorer?. What protocol are you using VXI-11 or socket?.
DiegoF
National Instruments.
(4,086 Views)
as I said, I tried the wavepro 9xx drivers, but those don't work. the 7200 is a totally different scope from the WavePro 7000 (recently released). I have successfully set up the TCP/IP resource in MAE.
I'm guessing the main issue here is that someone needs to develop drivers for the LeCroy WavePro 7000, but I'm trying to find a hack to get it to work in the mean time.
-Jonathan Eisch
University of Wisconsin, River Falls
(4,086 Views)
I tried the wavepro 9xx drivers, but those don't work. the 7200 is a totally different scope from the WavePro 7000 (recently released). I have successfully set up the TCP/IP resource in MAX.
The word on the street is that the WavePro 7000 drivers are in the pipeline.
-Jonathan Eisch
(4,086 Views)
The drivers for the WavePro 7000 are now available on LeCroy's website and work beautifully with LabView 7.
-Jonathan
(4,086 Views)
