List of present serial ports
I need a list of serial ports on a computer, so I can scan these to find which is connected to an external device.
The application is expected to be distributed to many computers with different hw & sw configurations.
My problem is that I only want the present seriel ports listed - that is, the same ports as those occurring in Windows Device Manager.
When I use Visa Find Resource.vi, I get a much longer list, which I think includes virtual ports also on devices currently not present.
Anyone knows how to obtain this list ?
I have tried the code below, and it works OK on Windows XP (I get a long text string that I can search in), but I am not too happy because I am afraid it will not work on other Windows versions:
Jan Nielsen
Freelance system analyst and LabVIEW programmer
(5,772 Views)
Accepted by Jan_Nielsen
Hi Jan.
I have attached a VI that uses the 'VISA Find Resource'-function. This gives a list of all the parallel ports on your computer.
Take a look at the VI and let me know if this is what you want?
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(5,745 Views)
Thanks Alex, but I can't open the VI, my LV is 2011
Can you please save it in 2011 ?
Jan Nielsen
(5,741 Views)
Sure Smiley Happy Attached is the 2011-version.
Best Regards
Alex E. Munkhaus
System Engineer
(5,739 Views)
Thanks Alex, this is exactly what I need !
Jan Nielsen
(5,736 Views)
This is a great tool! I had a need similar to this for a project I have, but wondering how one might take this a step further and make the list a selectable list.  I.e. the user could select any comport and then have the test save that selection as say a string to feed into a cluster later.
(2,871 Views)
