10-20-2017 05:04 AM
My apologise for mark myself as person who solved my problem.
It was a mistake. Too much work.
10-20-2017 07:50 AM
Thanks a lot .Actaully my main problem is to make an IV curve and get the data from thr buffer. Do you have any IV curve program?
cheers
10-20-2017 09:23 PM
Download the Keithley driver from - https://www.tek.com/source-measure-units/2450-software-11
Under examples, look at "Sweep and Acquire Measurements.vi"
Craig
10-24-2017 07:51 AM
I tried to run Sweep and Acquire Measurements.vi but I can't. Your IV test works but I cannot run any of the other programs, I got errors about configurations of ranges
10-24-2017 08:31 AM
You should start a new thread since its obviously a new question.
What values are you trying to use? The K2450 does have sourcing limits you need to be aware of .. https://www.tek.com/sites/default/files/media/media/resources/1KW-60904-0_2450_DataSheet_0.pdf
You can source up to 20V/1A, but above 20V the maximum source current is 100mA. Make sure you set the compliance to 100mA if you try to sweep past 20V. See the above spec sheet.
Cheers.
10-24-2017 09:02 AM
It doesn't matter what values limit level,delay or speed I use, It seems to be an autorange configuration issue
10-24-2017 10:16 AM
Start a new post and explain what you are trying to do explicitly.
Show the error messages you get, or the debug traces of the strings sent to the instrument and report actual settings.
Without more info we can't do much to help.
