Looking for GPIB drivers for Agilent EPM-P pwr meter for LabVIEW
Anyone know where I can get this?
Thanks...
-Umar.
(3,710 Views)
Go to the Instrument Driver Network and do a search for the actual model number that you have There is a 4416 and 4417 (single and dual channel).
Actualy, it looks like the same driver is used for both.
Message Edited by Dennis Knutson on 01-14-2008 10:45 AM
(3,707 Views)
I downloaded that driver and I havent been able to figure out how to put the meter in peak to peak average ratio mode.  Is it in the driver and Im missing it?
(3,445 Views)
Check the Configure menu and see if it's in there anywhere. If it isn't and you know the command you need to send, you can just use a VISA Write function to write that command to the instrument.
Justin E
National Instruments R&D
(3,422 Views)
