Looking for a GPIB Sytax for Testing on Code Channel to Reverse Pilot Output Power Accuracy
Hello everyone,
I am working on a module with Labview for  Testing 'Code Channel to Reverse Pilot Output Power Accuracy'.
The following is the link I got from Agilient:
http://wireless.agilent.com/rfcomms/refdocs/cdma2k/cdma2000_gen_op_overview_meas_wquality.php#BABCHH...
The test should be pretty simple but I didn't get any GPIB Syntax from the machine when operating on it.
It would be graceful if any programming example could be provided.
Appreciate it,
+Kunsheng Chen
(4,100 Views)
Looks like it similar to code domain power testing, I am not sure what's the difference between them.
thanks,
+Kunsheng
(4,062 Views)
Kunsheng,
I'm unclear what you mean when you say "I didn't get any GPIB Syntax". Are you not getting a response from the device you are connected to? If this is the case can you communicate with the device when you are not running this test?
Steven Zittrower
http://www.ni.com/support
(4,054 Views)
Accepted by Kunsheng Chen
Thanks, StevieZ.   The problem has been solved, I didn't recognize the test had already been done before.
(4,048 Views)
