Looking for instrument driver for Leica GO Systems TPS1100 series
Looking for instrument driver for Leica GO Systems TPS1100 series, TCRA1103plus. This is a theodolite which we need to program via RS232.
(3,444 Views)
You can look in our Instrument Drive Network at:
http://www.ni.com/idnet
If the driver is not available, you'll need to get the device documentation or contact the manufacturer for the command set of the instrument. Once you have the command set you can use the VISA Serial functions (or VIs) to send these commands to the instrument and receive the information.
Apart from the command set, make sure you get the serial por setting: Baud Rate, number of data bits, number of stop bits, parity and handshaking.
DiegoF
National Instruments.
(3,444 Views)
