MAX and IVI-COM driver for Agilent Infiniium scopes
Hallo;
I've installed the IVI-COM driver from Agilent for the Agilent Infiniium Scope 54833A.  If I open the Physical Names tab  for that driver ( under IVI drivers->Advanced->Instrument Driver Software Modules ->Agilent Infiniium) MAX 3.3.1.3004  just freezes. Is there a workaround for that problem ?
(4,128 Views)
As I know the NI-MAX 3.3 had a bug that it hangs up when you access Physical/Virtual Name mapping page.  The problem occured only when the IVI driver contains Range capability on Physical/Virtual Names as iteration.  Simple non-iterative mapping did  not have the problem.
On my PC, the latest NI-MAX 4.0 fixed the problem.  I believe the latest NI-MAX 4.0 comes with NI-VISA 3.4, LabWindows/CVI 8.0, or LabVIEW 8.0.
(4,117 Views)
I've installed VISA 3.4.1 now. But MAX 4.0.0.3010 still shows the problem.
(4,105 Views)
What version of NI IVI Compliance Packege are you using?  You can check the version at the following registry.
HKLM\Software\National Instruments\IVI\CompliancePackage\CurrentVersion
My CompliancePackage is 2.3 and the NI-MAX 4.0 operation did show the repeated Physical Names without errors.  What I checked is our Kikusui4800 IviDCPwr IVI-COM driver, where tons of physical channel names are shown in the Physical Names tab using a range iteration in the XML.  NI-MAX 3.3 did have the prblem with it but 4.0 does not.
If possible, I will try the Agilent's IVI-COM driver that you are using.  Can you tell me the URL where I can download the driver?  Otherwise, can you attatch the IVI Configuration Store XML file? The file is normally IviConfigurationStore.XML located in the ProgramFiles/IVI/Data directory.
(4,097 Views)
Upgrading to IVI Compliance Package 2.3 fixed the problem.
(4,081 Views)
