MAX does not see the computer's serial port (RS-232)
MAX (Measurements and Automation Explorer) cannot see the computer's serial ports (9 pin RS-232s).  I am using Labview 7.1, and running Windows XP (although I believe that the manufacturer has also installed Windows Vista).  When I go under Control Panel> Systems> Hardware> Device Manager> Ports, I do see both of the ports (COM1 and COM2), and both have the latest drivers on them.  Does anyone know of any way to add the "Ports" sub-branch under the "Devices and Interfaces" branch in the Configuration tree in MAX?
Thanks in advance for any suggestions.
P.S.  Labview had been shutting down in the middle of editing a block diagrams a number of times before and I reinstalled it a few days (without getting rid of the problem, unfortunately).  I wonder if this problem with MAX is somehow related to that...
Message 1 of 8
(4,790 Views)
Do you have NI-VISA installed? You can check by expading the software listing in MAX.
Message 2 of 8
(4,789 Views)
Hi Dennis,
Yes, NI-VISA 4.4 and NI-VISA Runtime 4.4 are listed under Software in MAX.
Message 3 of 8
(4,784 Views)
1. How about your OS's version, is it a professional version or modified version? Mybe you need take care of your Operating System;
2. Please open your COM port's property dialog and check if the default value was change? this issue maybe happen on a modified OS.
Message 4 of 8
(4,766 Views)
Accepted by topic author DanceWiz
You could try upgrading to 4.5 or simply unistalling/reinstall the version you have.
Message 5 of 8
(4,762 Views)
Hi ghlaah,
It is an unmodified, professional version.  I checked the COM port's property dialog and the default value has not been changed.
Message 6 of 8
(4,756 Views)
Hello again,
I just upgraded to 4.5 and it has solved the problem.  Thank you very much for your help.
Message 7 of 8
(4,754 Views)
I suspect that reinstalling 4.4 would have solved the problem as well but I'm glad that it's working.
Message 8 of 8
(4,751 Views)
