05-05-2008 05:45 PM
05-06-2008 01:44 PM
Hi AJG,
It sounds like your Measurement and Automation Explorer (MAX) database folder has become corrupted. The Knowledge Base Document ID 42HG08DD: Why Do I Get a Measurement & Automation Explorer (MAX) Database Connection Error? discusses what might have caused this and how to fix it. If none of the suggestions in that link work, I would follow the steps in the Knowledge Base Document ID 4GA9TOQA: What is the Process For Removing MAX Database Corruption? This should take care of the problem you are seeing.
Regards, Mallori M.
05-16-2008 02:52 AM
