MAX reports error on scanning
It'll be the optical spec anny-  Yokogawa hasn't quite mastered GPIB
Message 11 of 15
(1,541 Views)
I was able to move the Coherent Power Meter to my USB network and get it off the GPIB network.  So if I can re-write software to point the new address, I should be fine.
Message 12 of 15
(1,541 Views)
Paul,
Sorry for the late reply, but your spy captures show exactly the same thing happening until line 3.  When asserting IFC (using ibsic), you can see that the return status does not have CIC (controller in charge) as true in the failure capture.  The passing capture correctly shows CIC is true in ibsta.
This is backed up by the fact that you get the ECIC error when using interactive control.  Out of curiosity, which command received this error?
Does one of these instruments have controller capability?  It could be possible that one of these is set to system controller which is causing problems in your setup.
I know that you have moved one of the offending instruments to USB, but I thought you may want another possible solution.
I hope this helps,
Steven T.
Message 13 of 15
(1,516 Views)
Steven T wrote:
Paul,
Steven T.
The Textronix TDS scopes all have contontroller capability
Message 14 of 15
(1,510 Views)
I have added the GPIB-120B at the end of the GPIB daisy chain with the Coherent meter all by itself on one end and all my other instruments on the other.
Now when I scan for instruments, MAX reports "To many Listeners".
Message 15 of 15
(1,462 Views)
