MAX says visa32.dll not found in WINNT\system32 directory. File is there, have reinstalled and rebooted just to be sure. Same error.
MAX says visa32.dll not found in WINNT\system32 directory. File is there, have reinstalled and rebooted just to be sure. Same error. Why?
(3,492 Views)
What version of VISA are you using? What version of MAX?. What OS are you using?
You can try using the lastest version, NI-VISA 3.0. The installer also includes the lastest version of MAX (3.0). The installer can be found in the Driver and Updates >> NI-VISA
DiegoF
National Instruments.
(3,492 Views)
