MKS 946 Vacuum | Visa Read Problem
Dear Community People,
I am using LabVIEW to get flow rate data from LabVIEW. I made an easy code(withoutwhile_loop.vi) using visa write and read. It reads the command. For example, for @253FR6?;FF it usually returns @253ACK-1.100E-2;FF. Here 1.100E-2 is my desired flow rate.
However I want to read this data continuously. So I used a while loop in 500ms wait time(withwhile_loop.vi). Now when I run the loop for each iteration, the read value is different. For example, for first iteration, it is @253ACK-1.100E-2, for 2nd iteration it is ;FF@253ACK-1.1, for others it is something else. I want the code to show in @253ACK-1.100E-2;FF format everytime so that after each iteration I can extract the value(For this case -1.100E-2).
Could anyone help me what I am doing wrong exactly?
I have attached both of the code.
Additionally, how to find out what's the correct byte count?
Thanks.
(2,689 Views)
Accepted by Jarir
Hi
In the first iteration you read  @253ACK-1.100E-2;FF
Including all characters this is 19 character and you only ask for 16, what happens?
You better can ask for 100 chars and have a semicolon as end character.
Look at the examples\Instrument IO\Serial\Continuous Serial Write and Read.vi
You can get at this by help/find examples and then type in serial
They use char 10 as endcharacter, you should fill in the ascci value of the semi colon.
greetings from the Netherlands
(2,602 Views)
You might want to also give this a watch: VIWeek 2020/Proper way to communicate over serial
(2,598 Views)
