 Broussard
			Broussard
			11-29-2007 07:31 AM
11-29-2007 09:10 AM
Got it.....
thanks,
ZB
 TomLeamon
			TomLeamon
			03-13-2008 02:27 PM
Zachary -
Can you give me some insight into your solution? I've got the same situation right now:
Error: -1073807339, from the Modbus Recieve Message VI.
WatView talks fine to the F4 so, like you, I assume my comms are all ok.
Any help would be appreciated.
Tom
03-14-2008 08:48 AM - edited 03-14-2008 08:51 AM
 TomLeamon
			TomLeamon
			03-14-2008 09:01 AM
 niccolo
			niccolo
			06-03-2008 05:07 PM
 klqn
			klqn
			10-06-2009 04:35 PM
Can you or someone post a fix for this? This error is killing me. I am new to this and need the details how to fix it.
thanks in advanced.
kn
 Edgar123
			Edgar123
			11-06-2009 03:03 PM
Does anybody have a basic VI to talk to the watlow F4. I have been attempting to communicate with my f4 thru labview with not luck. I can communicate thru watview no problem, I have attempted several things with no luck and I just need help
Thank you,
11-09-2009 05:17 PM
What have you tried and what errors have you gotten? Do the previous posts help at all? I don’t have their code, but it may be beneficial to post your code.
 jeb55
			jeb55
			03-22-2017 06:15 PM
Maybe this example could help.
I tried reusing some of the provide scripts form watlow with no luck. After trial and error the following scripts seem to work for basic commands like set and read temperature.
Controller Single channel F4
Communication: RS232 modubus via Lantronix xDirect-IAP Lan to RS232 modbus adapter.
(Pin 11 on the F4 was connected to pin 9 on the Lantronix adapter for power.)
